Are all chainring b...
[Closed] Are all chainring bolts created equal? Unscrewing issue.
[#5208612]
I've got an old school Race Face Turbine five arm crank with Middleburn 'rings.
My Shimano chainring bolt tool is too wide to sit in the chainring bolt slot.
Is there a smaller diameter tool?
Posted : 01/06/2013 3:25 pm
 cp
A file on your shimano tool?
Posted : 01/06/2013 3:26 pm
I'm reluctant to do that as I've owned it for nearly thirty years.
Posted : 01/06/2013 3:28 pm
I recently purchased the park tools version, it's double ended and each end is a different size, so I can believe that there is more than one size of chainring bolt.
Posted : 01/06/2013 3:34 pm
Drill out the bolts and replace with ones will hex key on both sides
Posted : 01/06/2013 3:47 pm
spxxky: can you link to any as I could do with some after a stuck chainbolt issue.
Posted : 01/06/2013 4:09 pm
 imn
@stayhigh - when the same happened to me a couple of years ago I got M-Part bolts which have hex profiles on both parts. HTH.
Posted : 01/06/2013 6:24 pm
I sprayed some penetrating oil on em and then used circlip pliers to hold the back of the bolt while I turned the Allen key
Posted : 01/06/2013 6:46 pm
Cool, will check out the M:part ones. Cheers for that 🙂
Posted : 01/06/2013 11:06 pm
Big screwdriver is my normal tool, as long as the bolt hasn't gone all the way through obviously.
Posted : 01/06/2013 11:09 pm
Get some metal from the shed and fabricate one its easy. If else big screw driver or a kitchen knife.
Disclaimer no knifes from the wedding set might anger the wife as they might bend/break
Posted : 02/06/2013 9:54 am
Just come back from a ride. Came across a young lad with a brand new Inbred which had dropped two of its chainring bolts! A bit shoddy I thought........and a long walk back for the lad.
Posted : 02/06/2013 11:50 am
