Anything I can do t...
[Closed] Anything I can do to make this rear shock fit?
[#7696006]
Short of machining a new suspension rocker or filing out some material, does anyone have any ideas here?
It's a Cane creek double barrel air CS, on a 2014 Trek Remedy 9. Got the shock used and thought I would give it a go, but no luck.
The canister is so wide that it hits the seattube, preventing both eyelets lining up with their respective bolts. When upside down, the air can hits the edges of the suspension rocker before, not allowing the lower eyelet to line up with its bolt.
Have tried the minnow link in slack and steep positions- slackening it helps a little but not quite enough. The image shows how far out I am.
Any ideas before I sell it on? (using 2x offset bushings and obviously the correct mounting hardware for it to fit)
Cheers! 😀
Posted : 08/03/2016 10:27 pm
And yes, it's been cleaned since! 😆
Posted : 08/03/2016 10:29 pm
New frame or new shock I reckon.
Posted : 08/03/2016 10:53 pm
Ball hammer to seat tube, win.
Posted : 08/03/2016 10:56 pm
Custom top rocker.
How much room behind the shock? Could you space the lower mount back a bit somehow?
Weld up the lower mount and re drill the hole?
Posted : 08/03/2016 10:57 pm
Hammer might work!
Posted : 08/03/2016 10:58 pm
That lower mount drops away under suspension compression doesn't it? Looks like it'll never fit, sadly.
Posted : 08/03/2016 11:10 pm
 ART
http://www.canecreek.com/products/suspension/db-air/fit-finder. Er no.
Posted : 08/03/2016 11:17 pm
Local ovalisation, as Dave Yates would call it 😉
Posted : 08/03/2016 11:19 pm
Worked well on many an Intense M1 🙂
Posted : 08/03/2016 11:21 pm
angle grinder to the seat tube?
Posted : 08/03/2016 11:22 pm
edit: nope, doesnt matter 🙂
Posted : 08/03/2016 11:27 pm
Lots of suggestions that would definitely invalidate the warranty of my fairly new frame! 😆
This one is interesting. Because as the lower mount drops, it pivots further away from the seat tube, and increases the clearance. It seems that under sag, the shock actually fits. But as you unsag/fully extend the shock, the rocker and lower mount move a little closer to the sear tube, creating the problem.
Looks like I'll be keeping the monarch on it for now then. Shame!
Posted : 09/03/2016 12:22 am
Got a Cane creek inline. It fits... Just! ... Upside down...
Posted : 11/03/2016 11:08 pm
