I've looked everywhere for some right length chainring bolts for my 1x10 setup (XT M785 ctanks and OneUp N/W 32t chainring with spacers).
Has anyone got the knowledge?
I can't get them tight enough and the whole set-up creaks like one-oh under load.
Thanks in anticipation.
Chris
Do mech hanger bolts work?
That is what I used for mine but does not have spacers
Thanks - will have a look!
12mm chainring bolts???
single ring application?
Unless ive read it wrong(wouldnt suprise me) then why would you need spacers with just a nw and crank setup?
Because OneUp provided them? I'm assuming it's down to the Q factor but if you know different please do help. (:O)
Do you have topdown pic of the chainring bolted to the spider?
Normally youd just put the chainring on the outside of the spider and bolt up with normal (single) chainring bolts.
iirc single are 6.5mm and double are 8.5mm
I think you can get them from Pro-bolt as well
Haven't checked recently though
Using an M785 XT chainset, no "outside" to the spider.
Ended up with E13 bolts off CRC, seem to be doing the job.
Thanks for all the advice 🙂
sis cycles maybe?
