I have revs at 150mm which feel ok down but too tall on ups and flats.
Who runs what forks/stems/spacers (how tall are you?)?
If you are an air rev user - whats your weight and what pressure are you using?
140 Talas on mine - tho they tend to sit at 140 apart from long ups or short but silly steep ones. 70mm stem and easton 720 bars, couple of 5mm spacers under the stem. Seems fine to a talentless unfit 5'10 rider.
Hi
I have a large Titus FTM carbon & run a set of Rockshox Revs 150mm on them; low rise bars & 110mm stem - as I like to stretch out...
They seem fine to me - but they are u-turn down to 110mm (I think). I am 6ft & 12st 12lb (& going up a bit over Xmas!).
2012 150mm Rev RL on mine. 1-1/8 fork with converter. 11mm spacers I think, EA30 stem.
I'm 5'9, average in pretty much every proportion! 166lbs without kit. I run them at the bottom of the suggested pressure (ie, I run the pressure for a rider weight of 166lbs, even though my rider weight will be nearer 190 or something).
Bike can be a little interesting on very steep sections or very tight switchbacks uphill, but it's a blast going down 😉
