Anyone using Rock r...
[Closed] Anyone using Rock roll lube or Chain-L lube ?
 jeb
[#1142790]
Hello
I am looking for a all-year lube for mtb, i dont mind lubing after everyríde, and wiping off old lube, as long i dont have to degrease the chain using chaindegreaser....
I used for the last 3 week the dry lube "Squirt", on my commuterbike, to see how it performed, it was ok, seem to last for 50km, and i just applied some after that, and wiped off, but then winter hit Denmark, where i live, and man, snow, rain, sub temp, and the chain turned totally rust red, must admit the road gets salted, but the chain is brigth red .........
So anyone using Rock roll or Chain-L ?
Chain-L:
http://www.mtbr.com/cat/accessories/lube/chain-l/lube/PRD_438505_131crx.aspx
Seems to get good reviews
Squirt :
http://www.squirtlube.com/index.php'''
Posted : 18/12/2009 8:07 pm
 carl
to save 50 opinions which will only lead you to 20 different brands drop me a mail at brakingthetrail@gmail.com with your mail address and i will send you a sample of chain-l,rocknroll,juicelubes new wet lube,muc off wet,purple extreme and some others to try.
to test properly you will have degrease the chain thoughly before using each one.Results will vary massively if you dont do this.
Posted : 18/12/2009 8:58 pm
