Keep meaning to go tubeless, but for years have had no issues with punctures and change tyres regularly.
In the last few weeks I have had loads of punctures. I still want to be able to change tyres regularly so would still rather not go tubelss. So are these tubes any good?
I've used it in the past and it worked ok but needed quite a bit of latex to seal properly. When the pressure dropped a bit low they did roll of the rim quite easily
That was with non-tubeless tyres though (Ignitors, in case you're interested). Rims were DT Swiss 4.2D rims IIRC.
I've since used the same rims with Superstar tubeless rim-tape & valves and that works brilliantly as well as being remarkably cheap, although it was with UST tyres this time.
