I've plotted a route around Ladybower reservoir using Bike Route Toaster but the elevation graph shows the route is flat.
Any ideas what I've done wrong? Is there a button I'm supposed to press for it to calculate the elevation?
The start bit goes over the water, you should fix it so that the route sticks to ridable areas only (bikemap was also showing 0hm difference before I fixed the course; the altitude profile was correct, though)
http://www.bikemap.net/en/route/3315810-testtest/
thanks, I tried sorting the route but the elevation profile was still flat in Bike Route Toaster.
Has a quick look at bikemap.net and seems to do everything bike route toaster does so might switch to that instead.
