Anyone use a Brand ...
[Closed] Anyone use a Brand - X CX Dropper?
[#10881093]
If so so did you fit the barrel adjuster?
Where did you mount the lever? any pics etc.
Ta.
Posted : 25/10/2019 9:57 am
I didn't fit the lever as it's on my XC HT.... only place I could fit it would be central next to the stem.
Never bother with barrel adjusters either (on any droppers)... or supplied cables, I buy good quality lined outer by the 10m and PTFE cheaper inners in 10's....
I stick it in... leave long enough to grab with pliers and let it stretch (still workls just looser)....then pull it through and cut off the end and recrimp...
Posted : 25/10/2019 10:17 am
Cheers Steve, just wondered if anyone had used it on a drop bar bike.
I like the idea of tucking it under the LHS brake lever so I can thumb it. Just not sure that's going to work.
Posted : 25/10/2019 10:36 am
Link for the curious
https://www.chainreactioncycles.com/brand-x-ascend-cx-85mm-105mm-dropper-seatpost/rp-prod159175
I might have to try one of these...
Posted : 25/10/2019 12:22 pm
