Anyone still riding...
[Closed] Anyone still riding 8 speed?
 ton
[#10539381]
been riding a 8 speed bit for the last week. and it has left me wondering why we ever needed any more. it just works so well.
anyone else a old fashioned bugger?
Posted : 18/03/2019 12:17 pm
Yes. On my Plug. It seems fine. Then I get on my 11 speed road bike and notice all the bits where I can find just the right gear that I couldn't before.
Then I get back on the Plug, and after a few days I forget about all the gaps and it's fine again.
Posted : 18/03/2019 12:20 pm
Yep, albeit on my old retro Kona. Works just great doesn’t it. M739 and/or M950 was peak drivetrain IMO (M739 more so for the lower cost).
I love the range on modern 1x11 and 1x10 but every configuration I’ve ridden since doesn’t index quite so perfectly.
Posted : 18/03/2019 12:27 pm
I have an old Cannondale hardtail with XTR 8 speed. About once a year I dust it off and take it for a ride round the block. 8 speed drivetrain is great, everything else about it sucks, forks and brakes are terrifying. My other bikes are mostly 2x9 or 3x9, which works fine, with one 2x11 XT. The 2x11 is the clunkiest of the lot, really does not feel like a high-end drivetrain.
Posted : 18/03/2019 12:29 pm
 ton
just bought 2 x cassettes 2 x chains and a couple of smaller chainrings for the future.
£10 for a cassette..........ace
Posted : 18/03/2019 12:33 pm
My sons new Trek is running 3x8. I offered to upgrade him to 10 or 11 but he said he doesn't need it as the gear ratios are already perfect for him.
Posted : 18/03/2019 12:35 pm
Yes, on 2 bikes, only my summer road bike has 9s. I do have a 9s shifter and 12-36 cassette bit hardly used it.
Posted : 18/03/2019 12:37 pm
2 x 8 yep.
Posted : 18/03/2019 1:37 pm
1x8 on the hardtail.
3x8 on the FS.
chains and cassettes are so cheap its not worth my time to wash the drivetrain, just replace when its worn out.
Posted : 18/03/2019 1:47 pm
I opted for a 1x8 drive when building my eldest's current bike as she simply doesn't need more clicks, her previous one had 9 speed and it was utterly pointless TBH she only ever uses the top 4-5 gears anyway. You can tweak the range to suit their little legs now with various casstte/chainring options available, so why spend more? I did consider 7 speed briefly, but went with 8 in the end... (SRAM)
My Gravel bike is on a bodged 1x9, I'd consider 1x8 for it though. I'm also building a friction shifting Commuter/gravel/winter roadie thing that will more than likely be used with an 8 speed cassette to start with (as that's what I happen to have dug out from my spares bin)...
Posted : 18/03/2019 2:16 pm
I tried to recently, as I read somewhere that the cable pull of a 10 speed SRAM MTB rear mech would work with an 8spd Shimano MTB shifter. Sadly, it wasn't true 🙁 . Imagine a thick 8 speed chain with a clutch mech.. perfect downhill setup!
Posted : 18/03/2019 2:24 pm
My commuter is 3 x 6, it works fine.
 safi
Yep, my hybrid is 1X8 and works well.
Posted : 18/03/2019 2:32 pm
Its the other way around, I'm using an 8 speed SRAM shifter with a 10 speed Shimano shadow+ derailleur, I had to make 6mm thick washer that goes between the cable and the cable clamping surface on the mech and use a longer cable clamp bolt. It indexes perfectly and the chain has never come off.
Posted : 18/03/2019 2:57 pm
The Proflex is LX/XT 3x8 mainly for authenticity
You have to remove the rear wheel to adjust the front mech. Those were the days when this was all just fields. In fact I remember when yawn zzzzzzzzzzzzzz
Posted : 18/03/2019 3:07 pm
Top bodging ballsofcottonwool 8) . You've not got a pic of the spacer have you please? I can't quite envisage it...
Posted : 18/03/2019 3:30 pm
Haven't got a photo of my setup, I got the idea from here, plenty of pics on the thread
https://www.pinkbike.com/forum/listcomments/?threadid=148662
Posted : 18/03/2019 3:50 pm
2x5, 3x7, 3x8, 1x10, 2x10 and 1x11 on 26(559), 27.5(584), 700c & 29(622), and 27"(630) wheels here!
Posted : 18/03/2019 3:53 pm
3x8 on the tandem - seems to be fairly resilient
Posted : 18/03/2019 3:56 pm
yeah, my 4x freeride ht bike and commuter have 8 speed. X2 and X3
Posted : 18/03/2019 3:57 pm
Yep.. 3x8.. 8 speed chains never seem to snap.. ride them into the ground then replace everything for under 50 quid..
Posted : 18/03/2019 4:37 pm
3x8 Claris on my 2014 crossrip. It works, doesn't seem to wear, has a decent spread if gears with no massive gaps. 9 speed is smoother but the "it just works" nature of 8 speed I value more than pretty much anything else these days.
Could go tighter of wider on the cassette for minimal cost when it does finally wear out, but not sure of the benefits tbh.
It just works, and keeps working!
Posted : 18/03/2019 4:57 pm
11-30 cassette with 24/238 chainset on the Wazoo, which works fine with the 29er wheels and keeps the sprocket jumps relatively sane, 11-34 on the rear fat wheel for an easier gear at the cost of an 8-tooth jump to the 34T! 😮
I keep thinking about trying a 13-26 cassette for smaller sprocket jumps and a gear range that covers me for shallow downhill and will get me up Dell Rd's ~20% max gradient with a bit more effort (today I took it "easy" sitting down in 24/30)... But I have a feeling that the rear mech https://www.halfords.com/cycling/bike-parts/gears-drivetrain-cables/shimano-rd-m310-altus-sgs-rear-derailleur-black won't be happy with having 26T as the biggest sprocket.
Posted : 18/03/2019 5:41 pm
Would eight singlespeed bikes count, all with different ratio? Failing that 1x8 on my Kona Joe.
Posted : 18/03/2019 6:02 pm
 kcal
touring / general purpose (avoids 'gravel') is 3x 8. Perfectly good enough.
Posted : 18/03/2019 8:02 pm
Yes, but it's an Alfine 😉
Posted : 18/03/2019 8:05 pm
Never saw the need to update, and test riding new bikes day in, day out, just re-enforces my decision.
Posted : 18/03/2019 9:39 pm
1xAlfine8, its great 🙂 And a singlespeed of course.
Posted : 18/03/2019 9:41 pm
Yes my 1987 Stump Jumper, I’ve had from new, now my touring bike is still on its original 8 speed derailleur and thumb sifters. Has had a few chains and cassettes but not for years and on a fair number of miles since last change.
Posted : 18/03/2019 10:01 pm
1*7 for me
Posted : 18/03/2019 10:08 pm
3x8 on my wifes bike.
Every other bike is 9 speed, with 1-3 gears at the front.
Posted : 19/03/2019 4:25 am
My commuter/ come wet weather/ do anything bike is a gt grade Claris. 11-32 rear cassette on a compact chainset, and it never skips a beat. Just had to swap the rear mech after an off, and a £11 altus rear mech has gone on without fuss. Job's a good one for me.
Posted : 19/03/2019 9:56 am
Just bought his 'n' hers Diverges with 2x8 Claris. Seems adequate.
Posted : 19/03/2019 10:03 am
Yes, mostly still riding 8 speed...
Posted : 19/03/2019 11:11 am
 Bez
Didn't 8 speed MTB components first appear in 1992? (Though most 7 speed thumbies work ok as 8 speed shifters.)
Posted : 19/03/2019 11:18 am
