Anyone running sram...
[Closed] Anyone running sram xx revs?
[#1899746]
Have seen some in the sale and wondered if they're worth getting over team air u turns?
Posted : 16/08/2010 2:59 pm
I'm running the XX rebas - only real difference over the Team is the X-Loc... which is brilliant.
If you don't use lock out really, then prob not work having.
I actually got them in the sale cheaper than I could get the Team version, so winner all around.
Posted : 16/08/2010 3:06 pm
I really like the look of them, the ones with the carbon crown and steerer 8)
Posted : 16/08/2010 3:15 pm
I'm running pike coils at the mo and never wind them down , only ever flick the lock out for long road or fireroads , what does the x-loc do?
Posted : 16/08/2010 3:24 pm
X-lock is a remote lockout like pop-lock, but it's hydrolic, rather than a cable... so more reliable and nicer action. Also, it has a remote barrel adjuster (on the bar mounted button) for adjusting the low speed compression damping, which can be useful. I never liked pop lock and so took it off my old Revelations and switched to a standard leg top lever for lock out and only used it for fire roads.
Now I've got x-lock I use lock out really regularly, I can jump out the saddle to sprint up a short climb and push the x-lock button to stiffen up the front super quick... I am aware that I am starting to sound like an advert here. Anyway, I like it, but I use it a lot.
Posted : 16/08/2010 4:21 pm
Cheers stooo , sounds good but is it fixed at 150mm? I read somewhere it can be adjusted on the fly?
Posted : 16/08/2010 4:33 pm
