Anyone run MTB rapi...
[Closed] Anyone run MTB rapidfire shifter on a drop bar roadbike?
[#6909142]
I run a 1x10 commuter but the drivetrain has finally had it after a few winters of grime and salt.
New bargain back wheel (rim was almost see-through too) has a shimano freehub so I'll be switching away from campag. Better availability of cheap kit I reckoned.
I think I might have an old rapidfire pod in the garage - would I be mad to try using that? Sti levers are well pricey and a bit over engineered for this ratbike. Fancied a bar end shifter but even these seem surprisingly pricey considering their relative simplicity.
Anyone done this? Is it a pain in the 'arris?
Can I run an MTB lever with a road mech and cassette?
Posted : 04/03/2015 10:51 pm
You'll need a 10spd mtb mech. Cassette will be fine.
Posted : 04/03/2015 10:54 pm
[s]sdb, why ? The RF must be old and so "old pull", won't it ?[/s]
EDIT - I take that all back 😳
Posted : 04/03/2015 11:00 pm
For the Rapidfire+ pod, how do you intend to fit it, given that a MTB handlebar has a diameter of 22.2mm and drop bars are 23.8mm, and that's only upto the point where the STI's attach.
Posted : 04/03/2015 11:04 pm
No relevance to your question.. Just wondering if you are actually from Findo-Gask?
Posted : 04/03/2015 11:11 pm
I like my bar end shifters. They seem able to shrug off no end of rain, and are not that [url= http://www.chainreactioncycles.com/shimano-dura-ace-7900-10sp-bar-end-shifters/rp-prod34322 ]expensive[/url].
Posted : 04/03/2015 11:28 pm
Not sure if it'd work for you, but apparently campagnolo 10 speed shifters index nicely with shimano 9 speed gears if you clamp the cable differently. Obviously only much use if you've lots of 9 speed stuff knocking about...
Looking at running this setup on my CX bike, think the info is on the CTC site called "shimergo".
Posted : 05/03/2015 8:01 am
Yes... I'm running a Alfine shifter on drop bars. I reamed out the clamp to fit the wider bars and it works well, although it does mean the top bar is a little cramped.
Posted : 05/03/2015 8:18 am
run it as a flat bar - much simpler.
As said, MTB pods are the wrong diameter for road bars
Posted : 05/03/2015 8:24 am
I run campagnolo 10 speed shifters with shimano derailleurs. It works fine. Ideally you are best to run 10 speed shifters with 8 speed cassettes or 11 speed shifters with 9 speed derailleur.
Posted : 05/03/2015 9:11 am
There is loads of info on internet on running a Campag / Shimano mix. It actually works fine if you get it right.
Posted : 05/03/2015 10:50 am
those thumbies thingies ? they take 10 or 9 speed indexed shifters.
Posted : 05/03/2015 11:55 am
