Anyone know what th...
[Closed] Anyone know what this is?
[#3757812]
Anyone got any ideas what it is? It came with the handbooks of my 2011 Trek Remedy, there is no mention of it in the instructions.
[img] https://lh3.googleusercontent.com/-VRmVAUVeVNg/T1n5IzqPgjI/AAAAAAAAA_4/B9UQorhgS48/s502/2012-03-09 [/img]
Posted : 09/03/2012 1:50 pm
it's a lockring tool
Posted : 09/03/2012 1:51 pm
lockring or something to do with an adjustment on your shock?
It's a c spanner.
Posted : 09/03/2012 1:56 pm
2011 Trek Remedy
is it a fixed wheel?
Posted : 09/03/2012 1:57 pm
I can't see any lockrings on my bike, I have looked at the rear shock and there is nothing evident. Fixed wheel, it's got gears if that's what you mean. It's got me bamboozled 😕
Posted : 09/03/2012 2:00 pm
is it for getting the stones out of horses hoofs?
Posted : 09/03/2012 2:05 pm
does it have an eccentric headset or pivot anywhere ?
Posted : 09/03/2012 2:07 pm
Its normally for removing wheel bearings on treks
Posted : 09/03/2012 2:09 pm
It's a 5 pence piece, or a 10p if you're lucky.
Posted : 09/03/2012 2:12 pm
Baby Robin
Posted : 09/03/2012 2:30 pm
An upside down and back to front metal question mark?
Posted : 09/03/2012 2:37 pm
looks like a skyhook..... or a jiggle-pin
Posted : 09/03/2012 2:39 pm
Cheers, as far as I know there are no eccentric bearings on the bike, it did have a bontrager 15mm front hub when it was new, So I can only assume it's something to do with that.
Posted : 09/03/2012 2:45 pm
coil shock?
Posted : 09/03/2012 2:49 pm
it's a C spanner for the lockring/platform on a coil shock.
Posted : 09/03/2012 2:50 pm
Coat hook for a cubicle divider on a glass riser.
Posted : 09/03/2012 2:51 pm
No coil just the standard RP2 with the Trek DRCV bit on the top
Maybe it was never supposed to come with my bike then?
Posted : 09/03/2012 2:54 pm
as said,thats a c spanner designed for use on a coil shock locking nut or on a motorbike style headset.
Posted : 09/03/2012 3:03 pm
tomatoevousparlour has it right..
Its for adjusting the preload on the front bearings, although typically they always came overtightened from the factory and destroyed themselves pretty quick sharpish.
Posted : 09/03/2012 3:08 pm
That makes more sense, as both my Top Fuels came with one, and neither had a coil shock, but both had Bonty hubs.
Posted : 09/03/2012 3:20 pm
It was a bit of a mystery round the workshop until I worked it out..
Posted : 09/03/2012 3:45 pm
It attatches to your Prince Albert for carrying that troublesome third shopping bag home from Greggs.
Posted : 09/03/2012 3:48 pm
