Anyone know shock e...
[Closed] Anyone know shock eye to eye length for SC 2007 Heckler
 scud
[#3557248]
I'm off to the Alps in June and currently ride 29er hardtail but have been offered a SC 2007 Heckler frame for a decent price.
As it is only going to be used for Alps duties, i'm thinking of fitting a coil shock, anyone happen to know the eye to eye length of the shock on this so that I can have a look at trying to price how much a complete build is going to cost me?
Thanks again STW wisdom..
Posted : 12/01/2012 3:23 pm
Drop the guys from Santa Cruz an email, they'll be back to you in no time.
Posted : 12/01/2012 3:36 pm
If you've not already got it I'll measure it at home this evening after work.
Posted : 12/01/2012 3:44 pm
200mm....I seem to recall on mine
99.99999999% sure (could be wrong) 😕
Posted : 12/01/2012 3:47 pm
From the Santa cruz website. (FAQ)
What size shock does the Heckler use?
8.5" x 2.5" (216x 63mm)
The mounting hardware is 22mm wide with an 8mm through hole.
http://www.santacruzbikes.co.uk/heckler
Edit. Not sure whether it's changed in last few years, so this is probably of no use 😳
 bbb
Both the Heckler 5.0 and 6.0 were produced in 2007.
If it is a 5.0 then the dimensions are 200 * 57
If it is a 6.0 then the dimensions are 216 * 63
Heckler 5.0
Heckler 6.0
Posted : 12/01/2012 3:49 pm
 scud
It is the earlier shape, the 5.0.
Thanks for all the advice, any of you guys own one, make a good Alps bike?
I'm 5'10" so right on the cusp of fitting between medium and large and was told that they TT length is pretty short?
Also, anyone had experience with using off-set bushings to lower the BB height and slacken it slightly?
Posted : 12/01/2012 4:55 pm
I have a 200x57 coil shock you can buy if you want - a brand new Elka stage 5.
Posted : 12/01/2012 5:03 pm
 bbb
Great Alps bike - really simple, robust and predictable.
I am in the fortunate position to have adopted another 5.0, so now I have two: one is a large and the other a Med and I am also 5'10".
The large climbs better than the med, but the medium is more fun on the downhills.
I like them both equally and to be honest there isn't much to choose between them size wise. The standover is virtually identical and the main difference manifests itself in the top tube length (the large is 20mm longer).
I haven't ever felt the need to use short shocks or offset bushings as both these frames just feel 'right' when I ride them - predictable and forgiving and fun - what all bikes should be.
Posted : 12/01/2012 5:10 pm
Ive had 2 5's and a 6. Great Alpine bike, 5 TT is shortish and BB lowish, offset bushings would be pedal banging possible compromise though as front end is 'not slack', 150+mm forks better IME.
first one-
2nd one original spec [img] [/img]
2nd one Alped up
3rd Elcheapo one
Posted : 12/01/2012 5:14 pm
Took mine 5.0 to the Alps last year. I'm 5'11 and it's a medium with a 70mm stem and 130mm forks and it worked for me, confidence inspiring. Didn't use a coil just an rp3 which was fine (ish) bit lumpy in big compressions it blew through quite easily and needed a bit of extra PSI.
Posted : 12/01/2012 5:20 pm
 scud
Thanks again for all the advice.
I can feel a purchase coming on!
Mikey 74 how much did you want for the Elka?
Posted : 12/01/2012 5:37 pm
£300 posted O.N.O.. It's brand new, never even fitted.
The shock retails for £470, but I am aware that the warranty only applies to the original owner, and that you may have to get new mounting hardware and get it tuned to the bike it’s going on, assuming the current tuning isn’t suitable (although according to spreadsheet on the Elka website it is the same tuning – MC30, MR30).
Posted : 12/01/2012 6:10 pm
Oops, forgot: e-mail mikek@skylinecad.plus.plus.com if you are interested.
Posted : 12/01/2012 8:33 pm
