Anyone got a Talas ...
[Closed] Anyone got a Talas IFP tool?
[#357601]
i fancy servicing my forks, does anyone have one i can borrow? i could sort you out with postage
Tim
Posted : 03/03/2009 1:50 pm
bumpety 🙂
Posted : 04/03/2009 1:45 pm
You can use a standard football pump style adapter. It might take a couple attempts and 3 hands to ensure it doesn't leak air but it will work.
Posted : 04/03/2009 1:47 pm
i was wondering about that but 150psi is quite high isn't it
Posted : 04/03/2009 1:48 pm
also will the football pump adaptor fit on the end of a standard shock pump?
Posted : 04/03/2009 1:49 pm
Yes and it worked fine for my 36's. You need to hold the adapter down firmly and make sure it's central to stop any leaks when pumping. The IPF has a valve so you don't need to worry too much about having the correct adapter.
Posted : 04/03/2009 1:52 pm
excellent thanks for the info. anyone got a spare footy adaptor?
Posted : 04/03/2009 1:56 pm
Buy one you tight git!
Posted : 05/03/2009 9:42 am
ok. just bought 3 off the bay for 3 quid. worth a try though!
Posted : 05/03/2009 8:31 pm
solamanda - it dosen't fit! how the hell am i supposed to connect it to the shock pump??
Posted : 16/03/2009 9:01 pm
