Anyone got a Planet...
[Closed] Anyone got a Planet X RT-58 and run two water bottles?
 igm
[#7077906]
If so what cages do you use?
Mine clash at the bottom, so I need some that sit higher.
Posted : 19/05/2015 11:17 pm
 Jrrr
I have the same bike and I have ran different brands of bottle cages. The important bit it is that the you can get ones which only have 1 fixed hole and the other is on a slider that allows you to position the cage higher on the bottle boss's.
I'm currently running two of the SKS Topcage mounts as found on CRC at the moment for a fiver a piece. Nice cage, secure bottles and doesn't scratch them up very much. Although though look rather like boring plastic compared to others.
Hope that helps
Posted : 19/05/2015 11:49 pm
 igm
Boring is fine.
Thanks for the info, it helps.
And available in green to match the green and white frame I have.
Posted : 20/05/2015 12:17 am
 igm
Any other suggestions this morning folks?
Posted : 20/05/2015 7:20 am
used elite race custom plastic ones on mine. fixed holes on both
cages put them far enough up the frame to not clash.
Posted : 20/05/2015 7:23 am
Elite Custom's have fixed holes but also have sliding mounts, I use them to mount my cages low but I'm sure you could mount them high using the same bits.
Posted : 20/05/2015 8:50 am
[url= http://mikesbikeshop.co.uk/DDT_ShowEntry_simple1.asp?GalleryName=Accessories&EntryID=975&ImageSeqNo=1 ]King Cage Iris[/url] are good. Hold bottles really securely and look awesome.
Posted : 20/05/2015 9:08 am
Elite race cage would be my suggestion too. Not got the planet X but have those cages on all my bikes and there is probably close to 20mm of adjustment.
Posted : 20/05/2015 9:17 am
Specalized Rib cages work fine on mine.
Posted : 20/05/2015 12:01 pm
 igm
Elite race customs fit beautifully.
Thanks all
Posted : 02/06/2015 4:59 pm
