Anyone got a Manito...
[Closed] Anyone got a Manitou MILO Remote?
[#7206340]
Does anyone have one of these attached to their Manitou forks:
[url= http://www.chainreactioncycles.com/manitou-milo-remote-assembly-kit-2012/rp-prod57817 ]Manitou MILO Remote[/url]
I'd like a remote on my Minute Pro's, as far as I can tell it should work. Does it just shift the forks from fully open to fully locked out? Or can you move it to a half way position and leave it there? by the look of the design all you can do is go the a fully locked position with the lever, and the release it to a fully open position with the button. Am I right? At the moment the knob on the top of the forks allows for any position from open to locked.
I've emailed the UK distributer, Hotlines, and have had no response.
Posted : 21/07/2015 8:09 am
Bump?
Anyone?
Someone... Surely?
Posted : 21/07/2015 1:50 pm
try manitou in the states
I had a question about travel reduction and they were incredibly helpful and replied quickly with loads of info
Posted : 21/07/2015 2:03 pm
I think it's on/off only:
AFAIK, RST has a remote lockout with a sort of ratchet in it that allows you to stop at an intermediate position.
Usually a return spring of sorts is also needed in the cartridge, you cannot simply add the remote your existing fork - at least with RockShox. It could be that Manitou adds the return spring to all cartridges, and simply removing the knob with the detents makes it remote-ready.
Posted : 21/07/2015 2:43 pm
@Kimbers - Thanks, I'll try Manitou in the States.
@otsdr - Though it's not shown, there is a return spring that fits under the replacement red cap which makes the return happen.
After a bit of Googlage and YouTubing about the matter - if I can just get the assembly that goes on the fork, I reckon an old twist grip shift would work well on the bar end as the actuator.
Posted : 22/07/2015 2:56 am
If you want to go the friction shifter route you could also look at Paul's Thumbies: http://www.paulcomp.com/thumbies.html
Posted : 22/07/2015 6:32 am
I've had one fitted to some Tower Pro's, it is only 2 position and it doesn't pull enough cable on my forks to go from fully locked to fully open, the lever only pulls enough cable for approx. 2/3rds of what is needed (so a bit crap really)
Something like that thumb shifter should work well or like above an old gripshift
Posted : 22/07/2015 6:59 am
