...or a really clued up retailer I suppose.
Im after a 3 speed gear hub with coaster brake and a long enough axle to work in a 135mm OLN frame.
The [url= http://www.ultimatepursuits.co.uk/search/results.aspx?product=sg-3c41&vertical=1 ]Nexus SG-3C41[/url] fits the bill but isnt listed on the ultimate pursuits site (only some parts for it).
However, the [url= http://www.ultimatepursuits.co.uk/products/details.aspx?ref=14228&pRef=82696&vertical=1&v= ]SG-3R40 is listed on UP[/url] as a Coaster Brake hub, but according to [url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/SG/EV-SG-3R40_BR-IM31-R-2317_v1_m56577569830609178.pdf ]Shimano[/url] it is for a roller brake.
So which is the right hub, which is available with a fitting kit, and can either be bought with a 175mm axle internal assembly pre-fitted or is an extra part required?
thanks.
I'd be very surprised if Shimano had it wrong
indeed. 'tis why I would like to get the right part numbers from Madison so that my LBS/me can order what I need without having to send back the wrong bits.
