Anyone else mangled...
[Closed] Anyone else mangled a foot nut on their Rockshox?
[#3368880]
Yes, I should know better.
Doing a lowers service on my Revs, tightened up the foot nuts using a torque wrench to the specified amount - got to about 3Nm (50% of specified) and the damper side bolt washer started to invert, backed it off and replaced the crush washer.
Then doing the air leg the base of the bolt, the half moon washer part of the bolt started to sheared off about 2Nm. Rubbish.
Trimmed the bolt down, and replaced the crush washer on the air side, put in 100psi in both chambers and popped down a drip tray - if it doesn't leak overnight I'll see if it loses anything during a ride.
Anyone done the same on their Rockshox? I'm guessing the air side can be replaced by a Fox M8 base nut, although the damper looks specific.
Ricks
Posted : 19/11/2011 7:05 pm
Ummm, no 🙂
Posted : 19/11/2011 7:51 pm
My advice: Don't do it 😉
Posted : 19/11/2011 7:54 pm
 LoCo
Red one was it?
Posted : 19/11/2011 7:56 pm
Both sides, I'm a numpty. Its a long base nut and the damper side. Still don't get why they went at less than 4nm.
Posted : 19/11/2011 8:28 pm
 LoCo
Got spares for everything plus those crush washers you mentioned the other day, will pop it all in the post monday 😀
Posted : 19/11/2011 8:30 pm
You sir, are a star. How about I pop over with some cake on Monday instead?
Posted : 19/11/2011 8:52 pm
 LoCo
tidy that's good too! MMMMM CAKE! 😛
Posted : 19/11/2011 8:56 pm
I noticed that the rubber bit on my lock out has come off, any ideas how to replace? Bike was from CRC, I've messaged them already.
Sorry for rubbish photo quality!
[img] http://c0014049.r32.cf1.rackcdn.com/x2_9650e01 [/img]
Posted : 19/11/2011 9:21 pm
 GW
Blu-tac and a 5p coin stuck on top
Posted : 19/11/2011 9:31 pm
Really? Cool.
I was trying to explain to a guy in the LBS and he said for me to take the bike in so he could assess as it could be a big problem as it shouldn't fall out. I just assumed it was a plastic/rubber bung to stop water getting in.
Posted : 20/11/2011 9:04 pm
 GW
uh huh!
the 5p coin stops shite sticking to the bu-tac btw (oh.. and looks amazing 😉 )
Posted : 20/11/2011 9:08 pm
Thanks GW.
I've now linked the two, but after e-mailing Chain Reaction to see if they could help (as that's where the fork was from originally), they recommended getting in touch with Loco Tuning - they also suggested the blu takc/5p thing! So thanks to Loco Tuning I now have the bung winging it's way to me.
I've now put two and two together (oh and checked his profile) and realised that LoCo is Loco Tuning. 😛 Anyway top marks and thank you LoCo.
Posted : 21/11/2011 6:42 pm
And.... thanks to LoCo from me - as I now have two new foot nuts and some spare crush washers 🙂 Whoop.
Posted : 21/11/2011 8:39 pm
Just a thought- Rickon, is your torque wrench OK- maybe it is not properly calibrated/ damaged or something?
Posted : 21/11/2011 8:45 pm
Just what I thought and a classic example of why relying on torque wrenches does not always work. The wrenches tend to be inaccurate at the extremes of their scale
Posted : 21/11/2011 8:47 pm
Torque wrench *could* be out, but I really wasn't putting that much torque through in - it's a small bar one, so anything more than 10nm is a bit of a struggle.
Posted : 21/11/2011 10:32 pm
