anyone been inside ...
[Closed] anyone been inside a reverb post yet?
[#3160460]
Need to save half an inch on saddle height. Wondering if it's possible to limit the travel inside the post. Does anyone have a schematic?
Posted : 18/09/2011 9:29 pm
bump
Posted : 19/09/2011 6:24 am
Sram have an exploded diagram on the Service section of their site, comes under the spare parts catalogue(think it was page 7 or 8), failing that, speak to the tech guys at Fishers, they'll have had quite a few of them apart by now.
Posted : 19/09/2011 8:03 am
2012 models comes with an external collar that limits travel. Should be possible to fit to a older model.
Posted : 19/09/2011 8:20 am
I've enquired about this and the answer I got was there wil be a new model out with only 4" travel....
They've had mine apart 4 times now 😈
Posted : 19/09/2011 8:45 am
I just got one, and I'm lucky that with it all the way into the frame it's just about perfect for road climbs. I want to drop it about 5 mm or so for offroad riding, but that's fairly easily done.
If you want to limit the height, surely the easiest thing to do would be use some paracord and a couple of zip ties to run from the top tube to the saddle? Very easy to set it to catch the post and stop any further upward movement.
Posted : 19/09/2011 9:12 am
Not sure i'd bother with a dropper post for 5mm 😉
Posted : 19/09/2011 9:23 am
Ah damnit! That's £230 wasted then.
Posted : 19/09/2011 11:26 am
??? I dont understand your comment.
Do you mean you want it to come up half an inch less but still drop - so does that mean the full height range is too much for you ?
Can you not put it in the frame lower then.
Posted : 19/09/2011 11:31 am
It's as low in the frame as it will go but puts the saddle height about half an inch too high. I'm thinking that something like a fork travel reduction spacer might work depending on what the internals are like. So yes, still want it to function as a dropper post but overall length to be half an inch shorter.
It's not for me, it's for a friend otherwise I'd have pulled it apart and had a look myself. I would imagine a spacer at the right point would stop it fully extending. It would be really lucky if the shaft was the same size as the fox one as I have some 10 and 20mm spacers spare.
Posted : 19/09/2011 12:31 pm
