Anybody use both lo...
[Closed] Anybody use both long and short sleeve Castelli gabba?
[#6851298]
I have the short sleeve one but find it cold this time of year on the arms when using the nano-flex arm warmers as they don't tend to be windproof.
I bought the long sleeved version, but before I try it and obviously won't be abale to return it, are the arms warmer in the long sleeved Gabba compared to short sleeved one with the nano-flex arm warmers?
Ta very muchly
Posted : 10/02/2015 9:16 pm
Can't answer your question directly, but I do have the long sleeve one and love it. I combine it with a sleeveless base layer and the gilet you can get that goes with it which I shove in the back pocket.
Posted : 10/02/2015 9:59 pm
I got both. Long sleeve better of the two options.
Base on under the long sleeve and it's good for coldest rides.
Posted : 10/02/2015 10:27 pm
Why no returns. Evans in Preston is good to do it in person if you prefer, no quibble!.
Posted : 10/02/2015 11:13 pm
I want to know if it works better than the short sleeved one, by seeing what others think.
If I try it and it's no different to the short sleeve then it will be a waste of dosh.
and you know how tight I am 😉
Posted : 10/02/2015 11:17 pm
 Haze
Can't really help since it's been too cold since I bought mine.
Planning on using it with my tried and tested Gore Windstopper arm warmers when the temperature climbs a touch, could be a cheaper option if your Nanoflex aren't up to it?
Posted : 11/02/2015 12:09 am
