Anybody running Hop...
[Closed] Anybody running Hope floating rotors with XTR disc brakes
[#2999245]
As the title says, I have XTR 985 disc brakes but dont want to run the centre lock discs as I want hope hubs. I want to know if this combo is ok I.e uneven pad wear etc. Any info very welcome.
Posted : 31/07/2011 8:18 pm
Just get the 6 bolt Shimano discs.
Posted : 31/07/2011 8:21 pm
The caliper will hit the rivets on the rotor...nothing that can't be solved with a bit of judicious filing.You can get Ice Tech rotors in 6 bolt you know,
I used them successfully for a while ,but changed to 6 bolt xt floating rotors which are a lot better.
Posted : 31/07/2011 8:25 pm
Yep running xtr with floaters but only 160 front and back.. (close but not rubbed yet.. touch wood 🙂
180 just wouldn't fit with prob filing away some of the caliper ;-/
Posted : 31/07/2011 8:38 pm
