Anybody got experience of making 07 Fox 100-140 Talas more progressive.
I have read somewhere that adding more oil to the air leg will make the forks more progressive as I find it uses up the first part of the travel really quick over rooty or rocky sections.I run about 20 mm of sag at present as if I run the recommended (all mountain plush) 35mm it is way too soft.
Any thoughts how much to add etc.
Thanks
Posted : 09/04/2014 3:52 am
Fist thing is the L in talas stands for linear which means it's not progressive to start with.
Top suggestion would be to find an RC2 cart for the fork and try that which should give you some more compression control.
Posted : 09/04/2014 4:29 am
Thanks for the advice I will look into that.
Posted : 10/04/2014 1:18 pm
