Has anyone managed to run shimano 11 speed sit drop bar shifters with 10 speed rear mechs on an 11 speed cassette?
Anyone done this with Campy Shifters?
Posted : 20/03/2015 3:48 pm
Forget about using Dura-Ace 7900 derailleurs with 11-speed levers. The derailleur’s shift-activation ratio is different for Shimano 11-speed rear derailleurs than it is for Shimano 10-speed rear derailleurs. Furthermore, Shimano 10-speed mountain and road rear derailleurs have different actuation ratios from each other, and the same goes for Shimano 11-speed mountain and road rear derailleurs. Prior to road 11-speed and mountain 10-speed, things were simpler; Shimano road rear derailleurs up through 10-speed and mountain-bike rear derailleurs through 9-speed all have the same activation ratio.And your intuition is correct that a Shimano 11-speed shifter will not work well with a 10-speed front derailleur because the 11-speed shifter is designed to actuate the longer lever arm of Shimano 11-speed front derailleurs
Posted : 20/03/2015 3:58 pm
Posted : 20/03/2015 4:04 pm
All I want is a clutch rear mech for 11s Shimano road sti.
Posted : 20/03/2015 4:09 pm
You and a lot of cyclocross riders.
Posted : 20/03/2015 4:16 pm
shimano are going to run out of actuation ratios soon and will accidentally create a 13 speed system that will work with 6 spd road mech and a 7 spd mtb mechThe derailleur’s shift-activation ratio is different for Shimano 11-speed rear derailleurs than it is for Shimano 10-speed rear derailleurs. Furthermore, Shimano 10-speed mountain and road rear derailleurs have different actuation ratios from each other, and the same goes for Shimano 11-speed mountain and road rear derailleurs.
and yeah the tourers will rejoice
Posted : 20/03/2015 5:03 pm
Dirty rider Im not so sure about your post as I'm running Ultegra 6800 shifters with a 5700 front mech without issues?
Posted : 20/03/2015 9:17 pm
