any surly karate mo...
[Closed] any surly karate monkey owners on here?
[#1116467]
i want to pick your brains re rear brake. thanks
Posted : 09/12/2009 9:54 pm
 ton
soon, hopefully............. 😉
Posted : 09/12/2009 9:57 pm
good lad 😉 tho yours will make my 16" look like a like-a-bike
What you want to know?
Posted : 09/12/2009 10:01 pm
stu ive put a rear post mount brake on and had a few punctures already. Not sorted it tubeless yet 🙂 and i had to removes rear caliper to get wheel out. Just wondered if there was a trick to avoid this or which is easier to remove for setting back up the is mount or the post caliper
Posted : 09/12/2009 10:10 pm
Amanda uses a hope bolt in rear hub.
Remove the bolts and the wheel falls out the bottom of the dropouts. 😀
If you've not got a bolt in wheel just slacken the top IS bolt and remove the bottom one.
You can then swing the caliper up out of the way and the wheel will slide out the back.
I've also seen someone use a wavy rotor and cut the back part of the lower dropout away. They then lined up the "dip" in the rotor with the top of the caliper and were able to get the wheel out.
The bolt in rear wheel is by far the quickest though.
Posted : 09/12/2009 10:21 pm
yeah a bolt rear wheel would be the best 🙂 im running this wheelset i can buy some more in a few months so will have a look at a bolt in one. Will try the is mount bolts next time i couldnt decide which would be more of a pain. Cheers stu
Posted : 09/12/2009 10:26 pm
im lovin my 18" KM..,i have the monkey nuts fitted and the rear wheel balance point is sweet for manuals..not what i bought it for!,with a 160mm disc rear hope mini mono fitted the rear caliper dosnt need to be unbolted for wheel removal..
Posted : 10/12/2009 12:18 am
first one ive seen with gears 😉
Posted : 10/12/2009 5:29 pm
what frame bag would that be?
Posted : 10/12/2009 5:37 pm
That looks brilliant coastkid! 😀
I'm almost regretting going for black with black bits...
singlespeed too slow for me... 😉
frame bag is by friend eric at [url= http://www.epicdesignsalaska.com/?page_id=4 ]epic designs[/url],for a 18" pugsley so its wider at front,had it on just to try it out,
BD it was supposed to be white graphics hence the white rims..oh well,
Posted : 10/12/2009 6:03 pm
The frame bag looks like an [url= http://www.epicdesignsalaska.com/?page_id=4 ]Epic designs[/url] to me. I have one of their bar bags. A great bit of kit.
Edit
looks like coastkid posted while I was looking for the link. 😳
Posted : 10/12/2009 6:04 pm
my poo brown one 😉
built to a tight budget mostly with bits i already had but i want to upgrade over time some nice wheels and a crank is first on the list 😉
Posted : 11/12/2009 2:46 pm
Poo brown was a good colour. I think on balance Camp Stove Green was best though. 🙂
Posted : 11/12/2009 3:08 pm
ive just searched out that colour and it is indeed very nice 😉 i wish my crosscheck was another colour but black but such is life 😉
Posted : 11/12/2009 3:19 pm
btw coastkid are you running top tube cable guides ? if so which ones fit properly cheers mick
Posted : 11/12/2009 3:58 pm
only my disc cable is up top mick,held with m-part brake line holder thingys,heres eric-bag makers camp green KM,note the 50mm wide una rims and spikes..wicked!
Posted : 11/12/2009 4:55 pm
