As title, for short commutes, gonna get cold soon and then getting rained on will be more of a problem. Looking for a lightweight waterproof jacket to keep in bag, but with underarm zips please. Any about?
+ cheap.
Following for interest
if your local store has one of [url= http://www.halfords.com/cycling/cycling-clothing/jackets-gilets/boardman-mens-waterproof-jacket-black ]these[/url], they are decent value for money
I ride to work in my Marmot Precip.
Underarm zippers, the pocket lining is made of mesh, so when it's hot it is usually enough to open the pocket zippers to cool down, pretty breatheable, and stylish looks for everyday use.
Not cheap, though.
Edit: It is packable down to a very small size, but no carrying pouch provided.
Go Outdoors have the Montane Spine on offer, Gore Tex Active shell under arm vents packs small and light.Its not cheap but cheaper than it should be .
My Rab Kinetic Plus jacket is waterproof and *extraordinarily* breathable. I'm amazed by it. No pit zips but no need for them.
Rachel
I have an endura pak-a-jak or something. It doesn't have zips under the arms, but does have vents. It's not so breathable though... so you do tend to boil in the bag, if you get too hot.
I'm gonna have to check out the Kinetic.
I've got Montane Pertex. No zip underarm but breathable.
+1 for the Endura Pak-A-Jak, perfect for my 4 mile commute.
Endura Pakajak II looks like it might be a contender.
Wanted underarm vents as breathable either tends to be not-very-breathable-or-properly-waterproof or is very expensive.
Desired budget: 0 ~ £50
Also saw Polaris Quantum jacket on offer on their website, but judging from weight, it's not packable down to small size.
Pertex is a range of fabrics, not a jacket 🙄
Saying you have a Montane Pertex, is like saying you drive a Ford Galvernised steel.
Unless it is Pertex Shield, it won't be a waterproof either.
