Need new fron disc for my avid elixir sl's. Superstars rotors are much cheeper than avids, are they any good??
No problems with mine, but not done a lot of miles on it.
Had the Flame ones in 203/180, really bad fork judder. Swapped to the Vibe ones and it went.
Had some on for a year. They are marginally thicker than avid standards which makes changing pads that little bit harder. IT has not been a problem but if you are already struggling with changing pads then this will make it harder.
Otherwise ok and work like you would expect them to.
Got some flame ones. They do the job, although they seem a bit more flimsy/bendy than my hope equivalents, probably as they've got quite a lot of material cut out of them.
I have a Vibe one up front, no issues what so ever.
