Last year I built a hard tail from a Brand X frame, I really like it but at the time I just put a cheap fork on it and it really lets it down.
Anyone know of any really good deals, non boost. Something like a revelation?
Otherwise I'll gamble with something second hand.
CRC still have cheap Manitou Mattoc forks, I'm very pleased with mine.
Cheers, I'll have a proper look but a quick check doesn't look like they've got much left 140mm?
I have a set of 140 34s? They've done about 6 rides. Bought with a view to going on the next frame but plans changed. I'd have to check what they owe me. pm me if of interest.
The 160mm Mattocs adjust down to 140mm easily. Just need the tools (or to make them if you have the means) - I have a set I can lend out.
I have a s/hand Pike that is solid and clean.
The 160mm Mattocs adjust down to 140mm easily. Just need the tools (or to make them if you have the means) – I have a set I can lend out.
Thanks for the offer.
So these ones would go to 140?
What are they like?
I know they're boost but I can get around that.
https://www.chainreactioncycles.com/manitou-mattoc-comp-boost-forks-15mm-axle/rp-prod174909
EDIT: And just seen the 120mm go up to 140. And CRC list the 120 Pros for the same price as the Comps.
I’ve got THESE for sale & they come with a brand new 140mm airshaft.
Cool, will bare them in mind cheers. How easy are they to swap the airshaft over? I've never opened a fork up before.
Cheers, any more info?
How easy are they to swap the airshaft over? I’ve never opened a fork up before.
Tutorial HERE straight foward as part of a service.
Update:
Just ordered the Manitou Mattoc Comps, they were originally listed as Pros but after a couple of messages to Wiggle & CRC turns out they were listed wrong. They're boost so I'll use an spacers (and get a spare set for the day I take the wheel out on the trail).
Local suspension servicing guy will change the travel for me (so @simon_g thanks for the offer but sorted).
Won't be fitting them for a while as I'll be lending the bike out, and they're not getting shiny new forks before I've had a chance to try them out! 😀
Not sorted. Not sure if there was an issue with them or the guy that changed the travel put them back together wrong but they don't return to full travel and make some funny noises. Only took me about 3 months to finally get them on the bike only to be disappointed.
Hopefully he'll get them sorted.
Sounds odd? It really is easy to change the travel, just need to remove or add a clip on spacer.
It can be difficult to get the lowers back on without trapping air if like me he didn't use the special socket and it is important to add air with the forks inverted.
It can be difficult to get the lowers back on without trapping air if like me he didn’t use the special socket and it is important to add air with the forks inverted.
Can i empty them and re-inflate inverted to try and fix it? Turn bike upside down, deflate, re-inflate or is it too late now they're back together?
Yeah just deflate and inflate with the bike upside down.
Cheers.
With the air out should it fully compress under its own weight (plus wheel still in)?
It's about 40mm away from compressing. Actually have to lean on it reasonably hard to fully compress it
It feels like it's still got air in.
Sounds like there's air in Hydraulic Bottom Out if you have that, there's a second valve which controls the feel at the end of the travel. Empty that too?
I don't have that, this is only the comp, I guess that's on the pro?
I've just poked a cable tie down the seals and loads of air came out. It's now sitting fully compressed. About to reinflate 🤞
Good news!
From memory, in the service instructions you're supposed to add a little air to aid doing the bolts up at the bottom of the legs, fine if you use the thinwall socket but impossible if you use an Alan key in the airvalve to do it up until, enough of the head is proud to put a socket on it.
Ha jamesoz too late!
I might have to grind down a socket then....
[url= https://i.ibb.co/BNFyLPc/FA4494-CE-81-E0-47-FD-A163-F889-B4-D00631.jp g" target="_blank">https://i.ibb.co/BNFyLPc/FA4494-CE-81-E0-47-FD-A163-F889-B4-D00631.jp g"/> [/img][/url]
[url= https://i.ibb.co/nQtPHpq/0-F7-A9835-63-B5-45-B7-8-CFE-7403911-FC9-CF.jp g" target="_blank">https://i.ibb.co/nQtPHpq/0-F7-A9835-63-B5-45-B7-8-CFE-7403911-FC9-CF.jp g"/> [/img][/url]
This isn't quite what I was planning tonight.
Can't see anything obviously up with it though
I've never used a ground down socket but sometimes it's a right pain as the shaft keeps pushing into the fork before the thread takes, hence trapped air.
I've got Mattocs on two of my bikes and I prefer them to the Pikes on my Hard tail.
It's all back together and still the same. It's as if the pressure isn't equalising properly. As you inflate it you have to pull it out to get it to extend, something I'm not used to from my rockshox but apparently is correct? It then sits at full length. But even bouncing on it in the garage drops it down to about half travel, where it then stays with very little support e.g. I can easily push it down to bottom out.
What's going on?
I think I'm going to email CRC and see if they'll send me another set, although I'm a bit worried they'll just say tough as it's been apart.
It does sound like the airshaft isn't fully extended when bolted up. But send them back I can't see it being an issue they've been apart if something's not obviously damaged or rounded.
Edit to add
Unless I've had too many beers tonight the fork should be fully extended on fitting the lowers.
Unless I’ve had too many beers tonight the fork should be fully extended on fitting the lowers.
Which is where the 8mm socket vs allen key comes in, so I couldn't do it. BUT I've made sure there's no vacuum in the lowers by using a cable tie down the side of the oil seal. So bike upside down, no pressure in the air spring and cable ties down the seals, I can push and pull through the whole travel. Pump up while extending fork to 60psi, turn bike over and it sits at nearly full extension. All good so far.
Ride it around the garden for 2 minutes and it's sitting down at about 90mm and if I lean forward it compresses to nearly bottoming out.
It's going back.
looks in, backs out.
good luck.
The Sektors are back on 🙁
[url= https://i.ibb.co/hXrY7j3/9-CFFD120-1-BAA-4327-856-F-D4592-D5-D47-B9.jp g" target="_blank">https://i.ibb.co/hXrY7j3/9-CFFD120-1-BAA-4327-856-F-D4592-D5-D47-B9.jp g"/> [/img][/url]
I've spent far too much time in the garage playing with bikes this week rather than riding them 🙁
I've got pros, excellent forks.
When you put the air in make sure they're fully extended first, I've had them pack down once like you describe and this has sorted it.
Cheers but I've done all that unfortunately. I've even just taken them apart again this evening to adjust the pin in the middle of the inflate valve as I'd read people having issues with that, but didn't help.
And made sure I kept them extended while doing up the lowers.
I hope I'll get a replacement or get it repaired. I quite fancy a different frame and being able to change the travel so easily is a big plus.
It lost pressure over night so I think it's something to do with the valve.
If you keep the forks after warranty it's worth knocking up a ground down 8mm socket. It just makes the whole experience so much nicer.
Took me 1/2 hour with a pillar drill and a file.
Without the socket I was leaving the bolts quite loose to allow me to extend the legs and equalise the pressure before nipping up.
Cheers probably will do if I get them back, which I hope to.
CRC don't have any stock so if they can't repair them then I guess they'll refund me. Although they did say they might need to send them to Manitou who should definitely be able to fix them.
How did you get on with CRC?
I've just sent back one of my Mattocs due to a creaky CSU.
They're a bit over a year old so CRC said they'd have to speak to the supplier before I sent them back. They got back to me pretty quickly, I didn't have to point out the 2 year warranty statement on the Hayes/Manitou site and I've sent them off.
Well they received it last Monday and haven’t been in touch, I’ve just chased them by email. So don’t know yet 🙁
Good luck with yours
I chased a set of SIDs after a week on Thursday to be fobbed off because it hadn't been 14 days!
Wish I could say that to our customers at work, would make my life easier 🙂
Still waiting 🙄
Really? Mines been replaced with a brand new fork...
Nah only joking. Still waiting also, I'm not really bothered as I've been on the road bike with the crappy weather.
Slow service though I'll re-think my future purchases.
@jamesoz ha, I’m not sure you’ll get a new fork if mine are anything to go by. Apparently they don’t have a replacement fork to give me but have just offered me a credit note. I’ve said no and requested a full refund.
Let’s see what they say...
Seems odd, surely if they went back to the supplier they'd be able to repair them? Being as every part is available as far as I know. Otherwise why bother to send them.
I'm guessing they haven't done what they say they've done and my fork is actually sitting in the back of a warehouse somewhere having not made it to Hayes.
That was my thought or perhaps Hayes won't warranty CRC forks.
£200 refund received today. So I'm on the hunt again for a 140mm fork.
I rode the bike briefly the other day and the Sektor on it really is bad.
Been looking at the xfusion forks on Planet X myself, seem a bargain...
Only one of the Sweep 27.5 left.
Great fork, proper bargain, andvrvrn though it's not boost it happily fits a 2.8 tyre in with plenty of mud clearance.
X-Fusion Sweep 27.5
Sweeps are a decent new option for that price, especially with the roughcut damper. Better than the stock Yari imho, although the Yari can be made into a Lyrik- but different price again. Easy enough to reduce the travel too on the Sweep
CBA to read back through but r2bike are the best price I have found for RS.
Do have a look on there if you haven't already.
