GENUINE INNOVATIONS CO2 CYCLE
Can you use normal threadless co2 cartridges or do you have to use their specific ones ? Cheers.
A bit over-priced
Any good though ?
Dunno - I bought a different one but I remembered looking at it & thought it was much cheaper elsewhere
I have one. It takes either threaded or non threaded and is good. No freezing to your hands because of the plastic case, good releasing bits at a time so you have some co2 left. Not as quick as some though.
Yeah, these things are brilliant ... although I haven't had a puncture since fitting slime tubes, had one go down a bit on a ride where a big thorn was being agitated as I went along, pulled it out (the thorn that is) the tube sealed and I popped this thing on and whoosh! back up to pressure and off ... brilliant!
