Any experience of t...
[Closed] Any experience of this cheap dropper post
 StuF
[#9702251]
[url= https://www.ebay.co.uk/itm/RDK-REMOTE-ADJUSTABLE-DROPPER-SEAT-POST-5-HEIGHTS-125mm-TRAVEL-NOT-GRAVITY/282150776758 ]Redneck Dropper[/url]?
Or any other suggestions, I need a 27.2mm dropper to fit my old Cove HJ. Probably needs to be externally routed as the frame isn't drilled for an internal one, and there is such limited choice unless I fork out for a thompson one that would probably be worth more than the bike.
Posted : 04/12/2017 2:16 pm
You can always drill a hole. Plenty of people do it.
Posted : 04/12/2017 2:18 pm
Ks eten?
Posted : 04/12/2017 2:29 pm
Brand X do an external routed one which looks nice and tidy with no cable loop when pushed down.
Posted : 04/12/2017 2:35 pm
Sorry just looked and it's not 27.2 🙁
Posted : 04/12/2017 2:37 pm
Ks e-ten 27.2 (air spring/hydraulic, but cable actuated, external) works a treat on my son's bike:-
https://www.stif.co.uk/mtb/product/ks-eten-100mm-dropper-seatpost/13388
Like gold-dust though, it seems!
Posted : 04/12/2017 2:43 pm
+1 for the KS...I managed to pick one up from a german website last year, getting hard to find even then.
Posted : 04/12/2017 2:47 pm
test in bikeradar:
http://www.bikeradar.com/mtb/gear/article/cheap-dropper-seatpost-test-ks-eten-vs-rsp-plummet-49107/
Friend of mine uses the KS since one year. No problem so far.
Personally might pick the RSP. The saddle mount appears to be a bit better. RSP a couple more bucks expensive than the KS.
Posted : 04/12/2017 2:56 pm
I used an X Fusion on my Cove it was pretty bullet proof, they seem to have become expensive now though.
Posted : 04/12/2017 3:00 pm
I've got one of these https://www.ebay.co.uk/itm/Height-adjustable-Bike-Vario-Seat-post-Kind-Shock-ETEN-27-2mm-400mm-long/201865036182?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Goes up and down, not internal routing on my bike. Not had anything else to compare to. Copes with my 100Kg+ so far.
Posted : 04/12/2017 3:23 pm
I don't think the RSP plummet in that article comes in 27.2?
I used to have an older RSP Plummet that was 27.2, but it was a completely different beast - spring loaded, mechanical system with notches like this one:-
https://dirtmountainbike.com/bike-reviews/gear-news/rsp-plummet-the-cheapest-dropper-seatpost-weve-ever-seen-and-it-works.html
It broke after about a year, not recommended!
Posted : 04/12/2017 10:44 pm
StuF - Member
Redneck Dropper?
Had a Red Neck dropper. The bottom of the seat clamp assembly snapped. It functioned ok and for the record I weigh 100kg.
Was using a KS cruxi 27.2 internally routed post with the cable running through a bottle boss (no drilling) but the cartridge has failed and I need to sort it out.
Also have a Ks Vario with the lever on the post, works well with a little tiny amount of sag. Again the cartridge needs replacement. All the low end KS posts use a sealed cartridge which is annoying also the minimum insertion can be a bit stingy.
Posted : 04/12/2017 11:17 pm
 StuF
Went for one of the KS eTens ordered from [url= https://www.amazon.co.uk/height-adjust-seatpost-27-2mm-410mm-Seat/dp/B01FS1PO60/ ]amazon[/url].
Will report back once it turns up.
Posted : 05/12/2017 11:57 am
I've done about half a year on my redneck dropper. It's clunky, the lever is a bit rubbish but it requires zero maintenance and feels bomb proof. I'd buy another
Posted : 05/12/2017 12:10 pm
