While removing the cassette from the wheel somehow one of the pawls has fallen off the Freehub. And got lost !!
Anyone know where I can get hold of one ?, I have seen some for the older 2 pawl system but none for the newer spline which has 3.
The wheel set is a M1900
Any info appreciated
Anyone ?
TF Tuned are the UK service centre. They do the wheels as well as the shocks. Try diving them a shout for parts.
Thanks, phoned up TF tuned, said they only do warranty work
If you can identify the part, any LBS with a Madison account should be able to help you out. The M1900 uses a more basic freehub than the more expensive hubs (hence the pawls rather than the ratchet drive) but Madison distribute all the spare parts.
Thanks mboy
Update, the 2 pawl kit from CRC did the trick for under a tenner
