Any Brompton expert...
[Closed] Any Brompton experts out there?
[#4761489]
Apologies it's quite OT.
Want to know if anyone has tried to change the size of the rear sprockets on the 2 speed S version.
And whether anyone knows if the crank arm dust caps are standard size - or where I can get replacements.
Ta
Posted : 17/01/2013 12:19 pm
Yup - the problem with changing the rear sprocket (I presume it's the bigger one you want to change) is if you go too big it hits the chainstay - it's do-able but to go above 17t you need to file a bit off the frame.
Dust caps are standard size - have you got the allen key bolts or the older hex head ones?
Posted : 17/01/2013 12:22 pm
Thanks. Actually it's the smaller one. I cycle the embankment everryday and as much as I know how good spinning is for my legs - i need some more inches on each crank rotation. Is it a standard shimano/sram freehub? so i can use any sprockets...?
Posted : 17/01/2013 4:50 pm
You can in theory use any sprockets, but I don't know anyone who makes smaller than 12t - the 11t ones fit to the end of the freehub not onto the body.
Have you already got the 54t chainset?
Posted : 17/01/2013 4:53 pm
