Any 26 inch fork ba...
[Closed] Any 26 inch fork bargains?
[#9387443]
Looking for a fork that has:
140 mm travel min (max 160mm)
Two travel heights if possible
15/20 mm axle fine
Preferably 26in specific, but could go 150mm and get a 27.5
Am thinking about getting a beefier fork for a BFe build; I would prefer something with beefier uppers than my Revs.
Any suggestions?
Posted : 17/06/2017 10:00 pm
Honestly? I'd get a 27.5 fork - about 10mm difference and you've got a future proofed fork if you change the frame. They are cheaper than the equivalent 26" fork.
Not sure about bargains but chain reaction were good when I got my 26" reba's a couple of weeks ago. Should have bought 27.5 versions though. 🙄
Posted : 17/06/2017 10:10 pm
This is cheap
http://www.bikescene.co.uk/Rockshox-Sektor-RL-Gold-275-150-9747-2-0.html
Posted : 17/06/2017 10:12 pm
650b Dual position Pikes were £399 @ Merlin
Posted : 17/06/2017 10:21 pm
Ive got some 2011 Fox Floats
140mm, Tapered Steerer, 15mm Axle. OEM of an 18" 2011 Orange Five
Yours for the cost of the postage.
New seals, unscratched stanchions. Been on my shelf for 3 years after I went to Pikes.
Posted : 17/06/2017 10:40 pm
^^^ hard to beat that offer !
OP I run my BFe (26 from 2012) with swtichable 110-150 Sektors, I think 140 would be a great spot and a bit beefier than the Sektors would be good too. So basically I am endorsing your choice.
Posted : 17/06/2017 10:45 pm
andyg1966, not to hijack, but if the op doesn't want those, could I put in an offer please- I'm after some cheap forks for a bike for my lad?
Posted : 17/06/2017 10:52 pm
Andy, wow. Many thanks. I would certainly be up for that, that is very kind.
Will try and PM you.
Chris
Posted : 17/06/2017 11:01 pm
Check around for offers on Manitou Mattoc's, great forks.
Posted : 19/06/2017 10:12 am
I bought a second hand set of 650b pikes from here for my 26" Bfe, they are 150mm and have the same axel to crown measurement as a 26" 160mm pike.
If you're struggling to get 26" forks you want I'd not be worried about fitting a 650b set
Posted : 19/06/2017 10:16 am
Offset is normally different though, whether you notice it or not but the fact that manufacturers went to the trouble to reduce the offset for 650b makes me think I'd rather have a 26" fork when running 26" wheels.
Posted : 19/06/2017 2:30 pm
