Have a Bandit on order which runs a 142 x 12 rear end would lke a hardtail as well which is the same rear to change wheels as and when
Transition Trans Am? You could start building a full set of Tranny's!
As much as I love the look of the trans am it appears to be quite heavy, would build into a lovely hardtail but a bit heavy at 6.4 lbs for the frame
The red does look V nice.
That would be colour of choice aswell!
if it were me I'd either;
1) try and find a wheelset that could convert from 135 to 142 (no idea if you can)
or
2) buy the hardtail frame I really wanted and get a rear wheel to match whatever 'standard' it uses.
I have a new 142 x 12 wheelset that is going on the Bandit but want a hardtail the will run these wheels without having to convert them when using them on the hardtail.
Nino Schurter's 650b Scale....
Was hoping for something less racey and more trail orientated
