Anthem X pivot bear...
[Closed] Anthem X pivot bearing life?
[#1939012]
My Anthem is just over a year old, and has recently developed a really annoying creak. Tonight I bit the bullet and took it to bits and all the pivot bearings are shagged - they feel like they are full of grit. I've levered off the seals and they look like they feel. I guess I was spoiled by my previous Marin's lifetime warrantied bearings.
So is a year about normal for Giant Maestro bearings? How much should I expect to pay for a new set (I think there are 10 bearings in there!)? What tools would I need to have to do it myself?
Posted : 27/08/2010 8:45 pm
Thread killed with the first post...
Anyone?
Posted : 28/08/2010 9:10 am
My trance ones lasted two years before eliciting cracking noises. LBS changed mine about £50 I think.
Posted : 28/08/2010 9:21 am
If they are anything like my old epic, 1 year-18 months is normal. There will probably be 8 bearings and 2 shock bushings to change. You can press the bearings in and out using some sockets and a vice.
I got an anthem this year but haven't been able to find the specs for the bearings anywhere.
Does anyone know what bearings an anthem X takes?
Posted : 28/08/2010 9:54 am
There are actually 10 bearings because there are 4 on the lower shock mount. I didn't press the bearings out but I did take the seals off, flush them out with GT85 and repack with grease - they feel better, but still pretty notchy.
And I've just reassembled it all without taking note of the bearing numbers. Doh!
Posted : 28/08/2010 12:16 pm
How did you get the seals off without damaging them?
Posted : 28/08/2010 2:14 pm
I have a very very small jewellers screwdriver and the seals can be levered off without damage. Probably related to the fact that they are not very effective seals.
Posted : 28/08/2010 2:18 pm
We use Enduro Max in our bearing kits which do seem to last a lot longer than standard ones. Have a look on the BETD website.
Posted : 28/08/2010 2:24 pm
Just heard from my LBS - Giant want £140 for the bearing set, so about £200 fitted. Since I only get to ride my bike at the weekends, that's about £4 a ride just for bearings. I'm not impressed.
@Hadge - BETD don't list a kit for the Anthem - have I missed something on the website?
Posted : 07/09/2010 11:03 am
I'd regrease as many as possible and replace only the shagged or critical ones.
Posted : 07/09/2010 11:11 am
How much! I did my trance myself with a full set of Enduro "full compliment" bearings and it was no where near that cost.
If you do not fancy the Enduro set then get the numbers and look to a local bearing supplier. It will be so much cheaper than the Giant cost, no pun intended. It is not too bad a job to get them out and refit them.
Posted : 07/09/2010 11:26 am
Mark, where did you get the Enduro bearings from?
Posted : 07/09/2010 11:31 am
Katek bearing kits for the Anthem X are £22 posted on Ebay
http://cgi.ebay.co.uk/Giant-Anthem-bearing-kit-X1-X2-XO-Giant-bearings-Anthem-/140447609689?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item20b3547359
I need a set for my Anthem X4 as it has started really creaking - less than a year old but gets used 4-5 times a week. I'll try cleaning and regreasing the bearings first and then fit the new ones.
Posted : 07/09/2010 12:04 pm
had my loverly orange and silver X1 for over a year. Its been used more than once a week. Also in the Lakes, Ben Nevis, Afan and plenty of races inbetween and not a squeek. Probably go on me tonight during a night ride over the SDW!!!!
Posted : 07/09/2010 12:48 pm
Maybe that's the answer - I should just ride more often 🙂
Posted : 07/09/2010 12:57 pm
Phew - now I am glad I bought a turner flux frame instead of a giant anthem X 🙂
Posted : 07/09/2010 1:04 pm
Just spoken to the LBS again. Apparently, that £140 is for not just the bearings, but the bolts and linkages - he says that for 2009 models Giant will not sell you the bearings on their own. Seems odd - can anyone in the trade verify this?
Posted : 07/09/2010 2:57 pm
