Anthem rear wheel -...
[Closed] Anthem rear wheel - dishing out or what ?
[#7117540]
Noticed on my Anthem that's about 2 months old that the rear wheel is closer to the nds seatstay that the ds one by a few mm. Took tyre off and had a look and it does look about 2-3mm towards that side. Frame alignment seems fine, tried the bit of string round headtube and through both dropouts and distance from centre of seat-tube to string same each side so frame alignment is fine, as I'd expect on a new Giant !
Will drop bike in to LBS who supplied it methinks. any ideas ?
Thanks
Posted : 08/06/2015 2:02 pm
Flip your wheel over and put it in the other way to check dishing? Think you have to remove mech for it to fit..
Posted : 08/06/2015 2:39 pm
^^^ now that's a good idea, assuming the rotor doesn't get in way etc etc , might have a look, ta
Posted : 08/06/2015 2:48 pm
