Just curious really, every review I've read states that they settled on 10-15psi OVER bodyweight in lbs. I'm 10psi under that value.
What are you running?
I only borrowed one for a while rather than owned one but I had it running at well over the recommended pressure before it was OK.
Mines got a rock shox shock on it, but I run it well above recommended pressure, but then I like my suspension relatively firm. Rides brilliantly.
I ran mine a bit higher from new.
14 stone fully loaded up and had it about 240.
Had the shock Kashima coated and set for my weight.
Now I run it about 200 psi and feels good.
Thanks,
Max
Crikey. I'm 12 stone - 168lbs - and have it at 155. A muddy woodsy trail ride with no jumps in descend mode today had the o ring at the bottom but not quite off the shock. I guess it needs to go up a bit.
how much sag were you running?
