Anthem 29er - fork ...
[Closed] Anthem 29er - fork upgrade
[#7859826]
I'm looking to upgrade the forks from the current 100mm Recons, is it worth going up to 120mm, or will it spoil the handling a bit? Happy to stick with 100mm I think if its a good damper and better controlled. Also, is there any advantage to getting a SID over a Reba or a Fox 32?
Posted : 31/05/2016 10:47 am
I can't imagine a 20mm increase would make too much difference in a negative way.
However make sure that the frame can take 120mm forks. Giant may state it is only suitable for 100mm etc.
Posted : 31/05/2016 11:07 am
Giant don't rate it for 120, but it hasn't stopped lots from doing it. Check out mtbr forum.
Posted : 31/05/2016 11:11 am
problem for me with adding longer forks os the bb height. slacker HA is desirable but i hate the feeling of high BBs. loads like it so it's a personal thing.
Posted : 31/05/2016 11:14 am
I thought by the time you maybe allowed yourself a bit (more?) sag the difference would be minimal, but like I said, I think a good 100 would be fine. Looking at second hand anyway, so not a huge gamble.
Posted : 31/05/2016 11:57 am
Love my X29 and thinking about a similar upgrade. Will watch with interest!
Posted : 31/05/2016 12:56 pm
I've done this on mine - now running 120mm X-Fusion slides. It's good, definitely makes the bike a little more trail oreientated given the extra travel and the bottom bracket is quite low anyway. I changed from 100mm Rebas and given they're a little taller axle to crown for a similar length travel x-fusion fork the height increase was pretty negligible in terms of climbing.
Posted : 31/05/2016 12:59 pm
Yes,
Run mine with a Fox Float 120 RLC.
Works well.
Removed a few spacers on headset to reduce handlebar height.
No real effect on climbing but a bit more confident going down.
Forks are for sale if interested.
300 posted.
singlespeedtothemax1@hotmail.co.uk
For photos and more info.
Thanks,
Max
Posted : 31/05/2016 1:05 pm
I doubt theres much issue with an extra 20mm. But think it's worth knowing that if you have an Anthem with the Overdrive 2 headset and headtube you will need to replace your headset too.
I recently sold my anthem 29er frame and didn't know about this, a few years ago Giant tried to introduce a new standard steerer size. It was tapered like all modern forks but the top of the steerer was 1 1/4 inches wide not 1 1/8.
Just thought I'd mention it incase you didn't already know.
Posted : 31/05/2016 3:05 pm
