anthem 27.5 140mm f...
[Closed] anthem 27.5 140mm forks?
[#7922212]
Hi.ive an anthem 27.5 2 with the rebas on.i was going to do the 120 change but been offered some 140 fox forks.would this be too much travel?
Posted : 02/07/2016 2:35 pm
to much it will throw the handeling way out and will void all warranty on the frame
the 120 change is sub £50 all well worth it.
Posted : 02/07/2016 2:37 pm
Would ruin a good bike IMHO. Pretty easy DIY job to increase Reba's to 120.
Or would you be better off with a Trance...?
Posted : 02/07/2016 2:42 pm
My Anthem's a 26 & from what I've read 120mm is thought as the longest you should extend travel.Could you reduce the travel in the 140's?
Posted : 02/07/2016 2:43 pm
Thanks .i will give the 120 a go.our rides have got more rocky hence the need for a bit more travel.might have to change bike later on but do like the anthem
Posted : 02/07/2016 2:53 pm
worth a go iv yet to find the limits of the handling under fast singletrack i find it makes you line pick a bit better insted of just smashing rock gaurdens
Posted : 02/07/2016 3:02 pm
