far away?
[edit] you edited!
screw on disk adapter for some weird hub?
Centrelock to 6 bolt adapter
looks like a 6 bolt disk adapter for a 155mm tandem hub - they are built to take a screw on drag brake
A bollocking for putting something metal on a nice table without a mat under it.
Adapter to fit a disc to a fixie/SS two sided screw on rear hub.
You bought it you tell me
Shiny thing?
Looks like a small chunk of turned alluminium to me?
Trendy cock ring.
Spaghetti measure?
Joss stick holder?
It's a
to be used as a
Trendy cock ring.
Or, to convert our tandem to take a disk brake in time for Heaven of the South...
You lot are too good/geeky!
DrP
flange
edit: Oi, I was still thinking (not to much effect admittedly)
a bodge
that looks nice and everything but you're going to have a bugger of a job if you ever need to service your hub. The adapter we've got on our has two side milled flat so that when you need to remove the adapter to get at the axle you can put the adapter in a vice and play at bus drivers. Thinking about it, how are you supposed to get any leverage on it to fit it in the first place? Finger tight will do I suppose but it will get tighter and tighter as you use it to brake...
You could easily rig something to use the M5 boltholes (I'd lash something up with an old rotor, other approaches are available). But yeah, flats would be a nice touch, though you'd need a big-ass spanner.
[i]how are you supposed to get any leverage on it to fit it in the first place[/i]
I suspect the notch in the side is designed to accept a suitable cold chisel/screwdriver blade.
[quote=Northwind a dit]You could easily rig something to use the M5 boltholes (I'd lash something up with an old rotor, other approaches are available). But yeah, flats would be a nice touch, though you'd need a big-ass spanner.
as above, use a vice. Seriously.
[quote=wwaswas a dit]how are you supposed to get any leverage on it to fit it in the first place
the notch is for the set screw to "hold" the adapter "in place" once fitted. 'Cos obviously, a 2.5mm set screw will hold the adapter when you are braking a fully loaded tandem with two riders doing 25mph down a hill... 🙂
Fancy tonearm pillar clamp?
When I saw the image online, I thought the notch was for a grub screw... But it's not - it's got 3 notches in it - possibly for a spanner arm?
Anyway, of all the challenges I face in my day to day life, I think fitting and removal of this, with hammer AND vice if need be, will be a fairly easy task!
DrP
Maybe it's for a fitting tool then as you suggest. OUrs does have a set screw, but I'm not sure it's too effective 🙂
I hate tightening things using vices, you can lose all sense of torque. Especially with wheels...
it looks sharp, be careful...
touché...
DrP
DrP - I see another split open finger coming soon 😉
