Bought the wrong one again 😕
Hi does anyone have this on their ASR5?
What size are these on the pick n mix? In CRC Thanks
http://www.silverfish-uk.com/ProductDetail/0/7198/Cane-Creek-Tapered-Headset
I've got a Yeti DJ which had a standard hope external tapered headset. 1 1/8th top and 1.5 lower cup. It's also the same on my Yeti asr7.
Get the pic & mix from Merlin cheaper than Crc plus 10% off hope at the mo
Is it Hope1 for upper....and type F for lower cup?
I will just go and measure my DJ lower cup and let you know mate. Ah I can't help you as I've just realized I've got a reducer lower cup in mine. Ask on yetifan and Andrew will help you out very quickly . I've just looked in my order history on merlin and type f is in there for my headset for my DJ so I presume you are right .
Im using a tapered fork if that helps.. Bought the 49IETS ..the lowers fit flush.. The upper would not. Im thick 🙁
