I'm trying to use a set of wheels built up with AC 6 bolt disc hubs (QR/QR) that appear not to have enough clearance.
Hubs are laces with Dlights to Crests in standard pattern (3x?) with hope floating discs. In a set of rockshox SIDs with hope race brakes the caliper rubs the spokes if the caliper is centred on the rotor.
Has anyone else had such issues? Is there a cure?
You checked that the wheel is dished properly?
You need one of [url= http://www.bicyclehero.com/gb/avid-rotor-hub-shim.html?gclid=CIHAxZbqpr0CFYQfwwodw4IASw ]these[/url] to move the rotor out a bit to clear the spokes,
It happens sometimes with some hub/floating rotor/fork combos that won't play together nicely..
