Am I being unreason...
[Closed] Am I being unreasonable?
 mesh
[#3189708]
Went to a reputable LBS to get a new rear wheel built for my Roadrat, had a good chat with the wheel builder to get something suitable spec'd (commuting with extra weight of panniers). Now I'd expect a good wheelbuilder to be able to spec and build a wheel tailored to my requirements, and for that wheel to be solid for a good length of time.
About six weeks later it has now bust a spoke on my normal commute (not clouted a pothole or anything like that) - my first reaction to this would be to go in and demand that they replace this and check the wheel over for free. Am I being unreasonable to expect this? Not sure if it's the pure frustration of it or if this is a justified reaction.
Opinions welcome but no, I won't name the shop 🙂
Phil
Posted : 27/09/2011 7:02 pm
Talk to the shop and see how they react.
Posted : 27/09/2011 7:11 pm
Many variables at play here..
it could have been a friday afternoon job..
Go in and be calm and ask if they can sort it out for you.
Posted : 27/09/2011 7:17 pm
Go in ranting,make sure you swear and make unsubstatiated accusations then threaten to bad mouth them on every forum known to man.Then wee in their shoes.Because that always helps 🙄
Or bear in mind
Sh1t happens.
Everyone is human.
You're far from perfect.
Posted : 27/09/2011 7:23 pm
Stuff breaks. It happens. Even new, well built stuff breaks sometimes. Take it back to the shop and see what they say. Don't go in all-guns-blazing, it rarely helps!
Posted : 27/09/2011 7:24 pm
a good wheel builder will offer a 'tune-up'. Was it offered and did you take it? Either way, wouldn't blow a fuse over it as a single spoke + true-up isn't worth the money for you or the shop to get upset
Had a wheel built up by my LBS. As part of the deal they said "bring it in after a few weeks and we'll check it doesn't need truing".
You could try that approach.
Posted : 27/09/2011 7:28 pm
As said above, go in politely and ask them to fix it. If they do so no problem with a polite smile then you know it's worth taking your business there again. Give them the opportunity to wow you with their customer service before assuming they're a bunch of crooks.
Posted : 27/09/2011 7:31 pm
I would expect it to be fixed free of charge and would be disappointed in a shop that wouldn't
Posted : 27/09/2011 7:36 pm
