Am I a superhero?
[Closed] Am I a superhero?
 lex
[#4167254]
Ok. Got some new wheels (hope hoops 29er crests) and had a lot of fun getting the tyres on. (conti mountain kings)
So. I go for a roll and both wheels have a wobble in them. Have I gorilla'ed them? Is that possible with my bare hands? Or am I looking at a replacement pair? (would be a huge ball ache)
Thanks in advance for your wisdom.
Lex
Posted : 16/07/2012 5:52 pm
its the tyres, not the wheels.
Posted : 16/07/2012 5:54 pm
I'd imagine it's more about the tyres not sitting correctly on the rims, than you've managed to knacker your rims.
Use a pensil pressed against your fork leg/frame to see if the rim is wobbling.
Posted : 16/07/2012 5:55 pm
 lex
I think the tyres are seated fine. Beads are the same all the way round. Quick check with a finger nail steadied against the frame suggests that the rims are out.
Posted : 16/07/2012 6:33 pm
Did you check to see if the rims were straight before?
Posted : 16/07/2012 6:40 pm
I have the same wheels and same problem, tyres are seated correctly but theres a noticable wobble, i still road it anyway.
Posted : 16/07/2012 6:46 pm
The spokes on Stans rims tend to lose tension when you inflate the tyre, its possible that this has caused the wobble.
Posted : 16/07/2012 7:10 pm
If they've been built correctly in the first place, Stans rims are designed to have their final tension once a tyre has been seated & inflated. Then removed and the final true up done
I reckon it's a dodgy build, so I'd be taking them back. Considering mine were fine for 8 months until I bent the front one in a crash.
Posted : 16/07/2012 7:14 pm
 lex
I assumed that they were straight when I got them.
Internet purchase from 'wobble' so returning them is going to be an a*Se. Might just ge lbs to do it and suck up the cost.
Thanks all, although I'm a bit disappointed to learn that I'm not a hero.
Posted : 16/07/2012 7:47 pm
