altura attack water...
[Closed] altura attack waterproof 3/4 shorts - wet bum - solutions/alternatives
 tor5
[#5910320]
Bought a pair just before christmas & they were great, have been riding through the deluge 2/3 times a week and they were great until a week or two ago when the bum started getting a bit damp, it has become increasingly moist over the past few rides.
I'm assuming this is because the water repellant coating has been worn away by the grit, mud and rubbish being splashed about at the moment.
Two questions; one, I'm hoping a wash and retreatment with nicwax will restore the waterproofing for some period of time. two, are there any better alternatives out there?
Cheers!
Posted : 31/01/2014 10:57 pm
I ran a pair for three years heavy use before they wore that thin on the taping I had to ditch them! I cleaned them regularly with tech wash and retreated with Tx wash in every fourth wash or there abouts. They must not be spun in the washing machine and must only be drip dried...no tumble drier!
If you have followed the wash instructions to the letter I am surprised they have given up the ghost so fast.
Are you sure it's not moisture travelling down your bib shorts/ liners from sweat?
Posted : 01/02/2014 12:07 am
Alternatives? A good set of mudguards. 🙂
Posted : 01/02/2014 12:19 am
Cover the inside of your shorts with gaffa or duct tape (kidnapping tape)
Posted : 01/02/2014 12:21 am
Only ride when its dry and sunny
Posted : 01/02/2014 12:24 am
Army surplus goretex over trousers from EBay, <£20 just cut down to required length. Pair has kept me dry for two winters now
Posted : 01/02/2014 8:04 am
I dont wash my waterproof jacket or trousers. Just take my shorts into the shower with me and rinse off then drip dry. My jacket just brushes off when dry
Posted : 01/02/2014 9:09 am
Normally water proof stuff is a membrane. THe fabric is also treated with a water repellent as that helps them breath.
Using a granger or Nikwax spray may help repel water from the surface an increase the breathability and the water proofing a bit. However, if you've damaged the lining then there is little hope for them.
Mudguards FTW.
Posted : 01/02/2014 9:15 am
