Looking for a stealth 120 to 150mm dropper in 31.6 flavour. Should i look beyond a brand x ascend? Currently got a 30.9 ascend external dropper which is ace!!
Similar budget to a brand x so no stupid £200 plus posts thanks - functional not flash!
Nope!
Can't think of any off-hand that aren't just the same thing with a different brand on it.
How much is the OneUp?
too much
Sounds like you know what to do then 😉
The only slightly bad thing about them is the remote, I've just bought a WolfTooth, at £70 for a remote it's a bit flash, but it's also absolutely lovely.
I don't mind the current Brand X 1x remote,b ut the Ztto lever is better and very similar to the Wolftooth but only £14 off eBay.
i have both brand x remotes already as have an external ascend
One Up V1 is around £130 at the moment. Pair it with ZTTO if you need a lever.
I have a wolf tooth and ztto. There's no functional difference.
One Up V1 dropper is £79.75 on their website now without a lever! Just got one to replace my wobbly brand X. I have a V1 OneUp on my other bike and its the most solid dropper I've used! no play at all in over a year.
Are the Brand-x / Canyon 30.9 posts still £50 on ebay without the lever?
I have a wolf tooth and ztto. There’s no functional difference.
Well... that’s disappointing... £70 bloody quid
20% off Oneup at the moment - annoyingly a week after buying one of their 180mm posts. Grrrrr.
I only went oneup this time because I could fit in the 180mm but couldn’t quite fit in the 170mm brand x.
If 150mm then just go for the brand x at £99 - it’s a no brainer. The cost of the oneup at $209 (worked out just over £160) doesn’t include a remote or cable inner / outer. Going to run mine with a Bontrager remote I already had.
Joebristol - Where is OneUp 20% off?
Their own website - use the code ONEUP2019
