Alternatives to an ...
[Closed] Alternatives to an FSA Orbit-Z headset
[#3556482]
About to replace one, so was wondering if there are any better quality or (even) cheaper alternatives? 50mm OD head tube, 1.125" fork, semi-integrated, very low stack - anything else fit that description? Google doesn't come up with anything equivalent....
Ta.
Posted : 12/01/2012 11:42 am
If it is standard zero stack it wil be 44mm ID, hope, nuke proof, cane creek + others do headsets suitable. If you want to replace it cheap then presuming the cups and races are ok you can just buy bearings for them. Google the numbers for the bearings and you should find them no problem, tehre are a few different types of bearings so it is best to remove the current ones and take the numbers off them directly.
Posted : 12/01/2012 12:01 pm
I believe it is a 50mm OD headtube at the cups (head tube is flared at the top and bottom - will need to get calipers on it to be sure) - the whole thing is jiggered, esp bottom cup/race. Years of trundling around with zero maintenance has taken its toll.....
Posted : 12/01/2012 12:07 pm
This would suggest the one you have has faired pretty well.
I had one of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=51070 ]these[/url] which uses standard cane creek bearings and it ran fine for a number of years with a bit of a clean out and re-grease every now and then.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=18084 ]This[/url] hope one will also fit but costs a bit more
Posted : 12/01/2012 12:17 pm
Thanks Rusty. Yeah, to be honest, for the cost of it, what it's gone through and how long it's lasted I really can't complain. I would be happy to do a like-for-like replacement and just look after it a bit better. The Hope looks like a pretty good 'bling' replacement mind - have to see how far the budget stretches as the drivetrain needs replacing as well (not for a lack of TLC this time!).
Posted : 12/01/2012 12:22 pm
As i said in my first post with the FSA headset using standard cane creek bearings you can pick replacements up for £10 -15 per pair, i never had any problems with the headset so wouldn't hesitate to recommend it.
I have not used the hope one but it gets good reviews.
When it comes to the drive train check out the sales but also have a look at some of the german sites they have been very competative of late.
Posted : 12/01/2012 12:29 pm
When it comes to the drive train check out the sales but also have a look at some of the german sites they have been very competative ove late.
Been there, done that, made the spreadsheet, saved hundreds 😉
I have a standard 1.125" Hope headset on my road bike - done thousands of miles and is still buttery smooth. Very tempted.
Posted : 12/01/2012 12:32 pm
Got a brand new one of these in black if you're interested!
Came with my new frame but wanted Hope to match my BB, skewers etc!
Posted : 12/01/2012 2:32 pm
Go on then - name your price and I'll have a think, but I think the Hope one may be on the cards 😉
Posted : 12/01/2012 2:40 pm
Looking for £30 posted 1st class!
Posted : 12/01/2012 2:53 pm
OK - I think I'm going the way of the Hope - so I'll pass. Ta.
Posted : 12/01/2012 3:01 pm
