Alternative 120mm f...
[Closed] Alternative 120mm fork to fox ?? your thoughts.
[#2792796]
Fox terralogic 2011 in cashima with big axle = £839.00 - ,m not made of money FFS - whats your thoughts on other brand 120mm travel forks and whats your reccomendation - up to 130mm ? .
Posted : 26/05/2011 7:38 pm
revs...
Posted : 26/05/2011 7:39 pm
 mboy
Rockshox SID's start at less than half that price from Merlin Cycles. Even top notch SID world cups are significantly less than that...
Posted : 26/05/2011 7:40 pm
 nuke
Might be worth having a look at Manitou Minute Pro 120. Thinking about getting some myself after reading the review in ST recently...seem decently light (3.5lb iirc), 20mm bolt thru and under £400
Posted : 26/05/2011 7:42 pm
 br
The 120mm Reba maxle is very good.
xfusion velvet?
Posted : 26/05/2011 7:48 pm
Reba RLT ti with 20mm Maxle lite.
Superb fork: light, stiff, incredible damping. I think On One have some deals.
Posted : 26/05/2011 7:49 pm
Reba is ok, but the damping is bobbins compared to the fox*.
*blackbox damper may be better, never tried it.
Posted : 26/05/2011 7:50 pm
Yep, it pees all over Fox open bath damping. Supposedly better than FIT too, but I've not tried that.
Posted : 26/05/2011 7:55 pm
Yep, Reba Team RLT ti black box is a great fork, every bit as good as a Fox overall. Still not quite as well contolled in compression (as a FIT 120) when it gets nasty or under really hard cornering, but a nicer spring progression, more tuneable at home and easier to look after / obtain in the first place. Very well rated, I like them a lot.
Posted : 26/05/2011 7:56 pm
Blackbox is basically motion control with the bad bits taken out. Better on balance than FIT, I think, certainly easier to set up.
Posted : 26/05/2011 8:06 pm
Just fitted some 120mm Sid XX forks and very pleased. Was running 120mm blackbox reba teams prior. They are a bargainiferous £429 at On One and definately an improvement on the rebas that were also excellent to be fair!
Posted : 26/05/2011 8:40 pm
Friend of mine has just bought those 20mm Manitou Pros and is very impressed. Dirt liked them too.
Posted : 26/05/2011 9:20 pm
Just bought some 2010 Reba Team 120mm Maxle forks from Jenson at a ludicrously cheap price. Will be finding out how good they are over the weekend but on paper they're pretty much the perfect fork for the riding I do.
Posted : 26/05/2011 9:55 pm
Posted : 26/05/2011 10:06 pm
I've a 120mm Reba SL - 2009 I think. Its a pretty good fork and the Moco is better than on my old Pike.
I used to think it was pretty much as good as it gets for a fork of that type, but I've recently retrofitted TPC+ to an old Manitou Nixon and that makes the Reba feel like its broken. The difference (Apart from full shim controlled rebound and compression - unlike moco) is the dual flow circuit/floating piston. For this reason, I'm thinking that black box moco (which has dual flow circuits) will be markedly better.
Posted : 26/05/2011 10:22 pm
I have some 2009 Reba Teams and Reba Races, both set to 120mm.. Strangely they both cost the same from on-one.
The Teams are considerably more stable in braking and when chucking my weight around.. They feel more invisible in use, if that makes sense. They're a piece of piss to service too. I can't really compare them to foxes as I've never owned a pair.. I preferred the idea of having some forks which are actually sealed.
Posted : 26/05/2011 10:27 pm
I've just changed from 09 Fox F120 RL to 2011 RockShox SID RLT Ti 120mm, really like them especially at £449 from On One.
They also have them in XX flavour for £475 with hydraulic lock-out, cheaper for lower spec's.
Posted : 27/05/2011 6:43 am
Marzocchi 44 Micro Ti set at 120mm (get the QR15 one if you can make your wheel fit).
Fabulous fork - I've got two now (one at 120 on a Decade Versa, one at 140 on a c456).
Posted : 27/05/2011 7:50 am
