Alpkit stem cell an...
[Closed] Alpkit stem cell and jet oil.
[#8386451]
Headed off to the outer Hebrides for a bit of bike based exploration. Could do with some bar storage. Does anyone know if a jetboil will fit in a stem cell?
Posted : 06/03/2017 3:57 pm
Not sure of the diameter of a jetboil but an Alpkit 650 Mytimug [b]just[/b] fits and I think that's 100mm diameter. You might want to check the height as well - if the jetboil is too tall/topheavy then you'll have fun.
Posted : 06/03/2017 4:00 pm
I thought this was going to be about stain removal. Disappointed.
Posted : 06/03/2017 4:01 pm
Diameter may be an issue. Why top heavy ab issue?
Posted : 06/03/2017 4:04 pm
The stem cells aren't particularly deep so if the jetboil sticks too far above the top of the bag then it has the increased possibility of falling out.
Posted : 06/03/2017 4:06 pm
Mine takes a standard 500ml bottle, with only the drinking spout poking out.
Posted : 06/03/2017 4:10 pm
 kcal
also look at others - Revelate stuff (sadly the website is throwing SSL errors...) Gas Tank but looks like there's a new one on its way.. "Mag Tank"..
Posted : 06/03/2017 4:46 pm
Don't think so - I have Jetboil Zip and Stem Cells but never tried it as the Jetboil is too big.
Posted : 06/03/2017 7:34 pm
I was trying to figure out the same thing last year. Lots of suggestions all of which meant spending loads of cash. In the end I carefully bent a wire bottle cage into shape to mount my jetboil on the seat tube. I strap a velcro band around to stop it making a bid for freedom on rocky sections.
Works very well.
Posted : 06/03/2017 8:01 pm
There's a new Stem Cell XL version, which is a bit bigger.
Posted : 06/03/2017 8:06 pm
 km79
New XL Stem Cell can take 125mm diameter, I think a Jetboil is 104mm.
Posted : 06/03/2017 8:11 pm
You might be better off with some Gorilla Clips and popping it on your forks or under your down tube.
Posted : 06/03/2017 8:37 pm
My brukit jackal fits in a stem cell xl easy enough. Jetboil probably would as well?
Posted : 06/03/2017 9:11 pm
What a let down, I was hoping this was some sort of 90's pubescent fantasy thead...
With the stem cell being used to transport:
I is disappoints...
Posted : 06/03/2017 9:24 pm
