Just got the above and my first set of RF Cinch cranks.
Does anyone know how to align it correctly? There's a little hole in the chainring which I guess is to help align it. I don't know what I'm aligning it to though!
Any one who has this set up please let me know.
If it's anything like the Absolute Black it will be to centre the dot with the centre of the crank arm. It's not clear on the Works one though.
I aligned it with the crank arm on mine.
If not the crankarm, what could you align it to?
I guess you could align it to points on a clock to change the effect? No idea that's why I asked.
I'm sure I had some Rotor rings on my roadie that could be aligned differently
They can be clocked forward or back depending on the exact need, but there's only really once place the default can go.
Align it with the crank arm is the default instruction. I have the same.
That's what I've done cheers
