Alfine snap ring fi...
[Closed] Alfine snap ring fitting
[#6146612]
Any tips regarding easing the fitting of the snap ring that secures the sprocket to an 11 speed alfine hub?
Thanks
Posted : 27/04/2014 4:15 pm
Small screwdriver, variety of swear words, lever it on like a tyre.
The swearing is the important bit.
Posted : 27/04/2014 4:18 pm
Agree with Ian, though there are some clips on U-tube just to be sure you're doing it right which helped me with mine.
Posted : 27/04/2014 4:25 pm
 nuke
Another agreeing with Ian
Never got around to it but read some file a little out of one end so next time you need to change the sprocket its easier to get the screwdriver under. Like the mid ring in this pic...
Posted : 27/04/2014 4:30 pm
Okay this is from memory...
Kneel on the floor with the wheel jammed between floor and wall, i did mine with a tyre on and inflated so minimising slip potential.
Hook on end into the groove and hold it there with one hand. Then with a small flat bladed screw driver wedged between ring and lip of groove like a tyre lever then just pull it round tweeking it downward if required. Basically because you have hooked one end the screwdriver it just forcing the ring into a larger diameter I swore lots then did it like that and it took maybe 30secs start to finish.
I found it was more of a one swift movement than and lever and move rou d a wee bit as it just pops out when you trh and move it.
Be carefulit does t require much force if you are doing it right.
Posted : 27/04/2014 4:54 pm
Thanks for your kind advice.
I upped the swearing and it finally went on.
The blood from my fingertip punctured by the screwdriver might have provided the required lubrication or maybe success with Alfine hubs requires a blood sacrifice?
Thanks again.
Posted : 27/04/2014 5:33 pm
I like to use external clip pliers or " snap ring pliers" . Opens it up like a circlip , place it on and let go.
Used to use external circlip pliers
Posted : 27/04/2014 7:11 pm
